Led sequence of 10
Discussion in 'LEDs and Optoelectronics' started by mick97, Oct 4, 2016.
  1. mick97
    mick97
    10
    Jul 31, 2011
    Hello everyone.
    I have a project that I wan't to use 10 leds lined up in a row.
    Basically 10 of them,with a switch up and down switch,so i can get the first one lighted,and hit the up switch to go to the next led.
    What would be the sequence of this to follow?
    Thanks,Scotty
  2. Colin Mitchell
    Colin Mitchell
    1,417
    313
    Aug 31, 2014
    1,2,3,4,5,6,7,8,9,10.
  3. mick97
    mick97
    10
    Jul 31, 2011
    Is there a thread that would tell me how to connect them,and what extra i need to make them light up one at a time?I know I need 10 leds,and a switch to toggle between them.
  4. Chemelec
    Chemelec
    291
    47
    Jul 12, 2016
    10 LED's, Probably 10 Switches.
    Or use an LM3914 Driver and a Single Potentiometer to adjust input Voltage.
  5. Alec_t
    Alec_t
    2,926
    796
    Jul 7, 2015
    Going by your avatar, is this project intended as a an indicator for effects pedals?
  6. mick97
    mick97
    10
    Jul 31, 2011
    No it is for a scoring game,so using leds to go up to 10.
    Ok,thanks on the other answer.
  7. Alec_t
    Alec_t
    2,926
    796
    Jul 7, 2015
    You could get the up and down counting done with a bunch of logic ICs, but it would be rather messy. The obvious alternative would be a suitably programmed MCU (Arduino, PIC, what have you).
  8. KJ6EAD
    KJ6EAD
    1,114
    159
    Aug 13, 2011
    You can manually clock an up/down decade counter such as a 4029 or 4192 using a debounced momentary switch and an up/down select switch. You could probably do it with a single 3-position momentary switch but it would require a bit more circuitry to delay the clock pulse until the direction was set. You probably need to include a reset or clear function as well.
