LED Sausage
A
Anthony Fremont
Jan said:
LED Sausage
Hmm..... It seems that the LEDs with higher Vf requirements lit first. Any
theories on that? I wonder if excessive Vr killed some instantly since they
never lit up. I'm guessing 120VAC was used.
Jan Panteltje
I'd look at the saussage as a resistor, with taps for the LEDs.
Depending on where the LEDs are some parts of that resistor would be
1.5V or more 'zeners' (LED forward).
If 120V was used that is 170V peak, and sousage is 20 cm, you have
170 / 200 = .85V / mm, for 2.54 mm LED wire distance that gives 2.159 V
for the LED.
But in reality more, because parts of the sausage are zenered.
So a LED that needs 3V would likely work too, and have more
energy by the same current.
The reverse voltage would be about within limits too.
As the saussage gets hotter and chemical reaction take place, the resistance likely drops...
Jan Panteltje
for the LED.
The ones that do not light up are perhaps like this:
no go go
A
Anthony Fremont
no go go
Yeah, I was thinking that was a possibility. Funny how the LEDs that lit
dissipated the cooking energy locally so that the as hot-dog swelled, a lit
LED made a constricting band in that area. I was also thinking that as the
dog cooked, the resistance was going _up_ causing more LEDs to light.
D
D from BC
LED Sausage
I wonder if unhealthy food conducts more electricity...
Ex: Salts such as the nitrates make food more conductive.
I bet cola is more conductive than milk.
And....I'll guess a greasy burger patty (McDonalds)conducts more than
a T bone steak.
D from BC
M
Michael A. Terrell
a T bone steak.
D from BC
Grease is an insulator. Any conduction would be from the remaining
water in the meat.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
R
Rich Grise
a T bone steak.
I'd take that bet, but I don't want to waste a burger and a steak. ;-)
I say the steak would be more conductive, because it's got continuous
meat, where the burger is interrupted by fat.
Cheers!
Rich
D
D from BC
Cheers!
Rich
Good point about the grease (oils) acting as an insulator..
But McDonalds patties are processed and probably contain ionic
compounds like salts for preservation and taste...somewhat like the
LED sausage.
I'll bring my ohm meter to McDonalds to measure patty resistance :)
Call it pohms (patty resistance).. :p
D from BC
R
Rich Grise
LED sausage.
No, you have to measure them raw, like the weenie was. ;-)
Imagine sticking two forks into a T-bone steak and plugging it in. =:-O
Cheers!
Rich
D
D from BC
Cheers!
Rich
I don't think I can get a raw McDonalds patty.. I'm not sure but I
think McD's receives precooked and frozen patties.
It allows stoned min wage teenagers to make burgers with a next to
nill E-Coli risk.
I plugged in a hot dog (120VAC) sometime in my teens and tasted it.. I
tasted metal.
Electrolysis occurs and I think the fork metal gets into the food.
Instead of forks...carbon electrodes into a steak would probably be
better.. (Part of the BBQ flavor is incinerated (carbon) meat
anyways.)
A T bone doesn't have the ionic additives of a sausage so the voltage
might need to be higher...Electrocution style cooking... mmmmmm :)
I probed a package of raw ground regular hamburger meat with a DMM.
3" probe spacing
1" probe depth
10 second settle time
1 test only
Raw burger meat resistance ~ 200kohm
D from BC
E
ehsjr
LED sausage.
D from BC
Naw - they're designing an ESR meter in another newsgroup.
Now we know the truth - it's an Effective Sausage Resistance
meter. Use that.
Ed
M
Michael A. Terrell
nill E-Coli risk.
Can explain why they need their automatic ovens, to cook the
patties? They are belt driven just like a pizza oven, with controlled
speed and temperature. I've seen them loading the thing at the local
restaurant.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
D
D from BC
restaurant.
Maybe it's because frozen precooked patties that are microwaved
dethawed and heated don't taste as good.
(I don't microwave chicken...)
The belt driven oven could be just a dethaw and reheat machine.
Precooked patties I think would also have the advantage of less
cooking time for more burgers per minute..
There's possibly less oven cleaning too if precooked patties are used.
I'm not entirely sure if McD's cooks from frozen raw or reheats from
frozen precook.
But I suspect frozen precooked patties.
D from BC
M
Michael A. Terrell
??? Restaurants collect and sell that grease. The cooking equipment
collects the grease into holding tanks so they can sell it. The salvage
company that buys it sends someone with a tank truck to pump out the
tanks on a set route. The grease is used to make hand soap, and in some
other industrial applications.
It would be quicker & cheaper to microwave them if they were
pre-cooked and frozen. I don't know about you, but I can taste the
difference in a fresh cooked, or a reheated burger.
frozen precook.
The patties I saw are pink, and were thawed before they are loaded
into the automatic oven.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
D
D from BC
Pink! That's good..
I'll confirm that on my next trip through the drive thru.
The tougher question will be if McDonalds can give me a raw patty :)
....Which could be combined with going through the drive thru naked...
(An old $100.00 dare from friends. Maybe I can get $130 for asking for
a raw patty with no clothes on.. :p)
D from BC
M
Michael A. Terrell
D said:
Pink! That's good..
D from BC
I would think that the health department would have rules against
them giving you raw, unpackaged meat. The same goes for the local
police. A stunt like that could get you a year in jail, and turn you
into a registered sex offender.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
K
krw
....unless you're in Vermont (no laws against nudity, though there is
against undressing/stripping in public).
