LED RGB control via analogue input?
Discussion in 'LEDs and Optoelectronics' started by Wilky, Jul 6, 2011.
  1. Wilky
    Wilky
    Jul 6, 2011
    Hi all,
    I have a set of RGB LEDs and controller that were 'left over' from a recent project. Please see below pics of the controller, it has two controls, one doing mode (constant / fade / flash etc) and one for speed.
    I would like to know if there is any way to control the R,G and B LED outputs by an analogue 1-10V input signal rather than the control buttons, after de-lidding i have seen there is a set of terminals labelled 'input'; R, G, B, and +. Could it be that this is just what i need?
    [​IMG]
    [​IMG]
    [​IMG]
    Many thanks.
  2. MagicMatt
    MagicMatt
    70
    Jun 15, 2011
    I'm pretty sure that input is going to be digital I/O. I've seen these things before, and that socket is for linking to other devices so that it can synchronise. I think you can link multiple LT-310's together so they all synchronise for using with longer LED chains etc.
  3. Wilky
    Wilky
    Jul 6, 2011
    Ok, thanks for the reply. I think you are right - I know these can be used as master / slave.
