LED project for a crown
Discussion in 'LEDs and Optoelectronics' started by Maskot, Sep 12, 2013.
  1. Maskot
    Maskot
    13
    Aug 7, 2013
    I'm a senior in high school and I wanted to add LEDs on the crown I've made for homecoming week, I wanted to use multicolor blinking LEDs since it would be the most amazing look.
    Here are the specs on the LED I picked out, I plan on using 6 in a continues series.
    Emitted color: red, green, blue, red green, green blue, red blue, red green blue
    Intensity MCD (typical): 250mcd (red), 580mcd (green) and 280mcd (blue)
    Wave-length nm (typical): 660nm (red), 525nm (green) and 470nm (blue)
    Lens color: clear
    Viewing angle (degree): 20°
    FW supply (V)(typical): 3.2V
    Peak current (1/24 duty cycle, typical) 35mA
    Capable of single or mixed color lighting and blinking
    Auto-start one-shot slow light up and fade, then blink
    On/Off key color change control: R,G,B,RG,GB,RB,RGB
    RoSH compliant
    The question is, how do I make them blink in different colors (complete setup since I have no idea what I'm doing, all I know how to do is solder) and about how much battery power would I need for at least 10 hours.
  2. (*steve*)
    25,497
    2,839
    How much time do you have?
    The simplest approach might be to use a 555 and a 4017 to power a sequence of 10 LEDs.
    Google "555 4017 LED" and you'll get a heap of things to look at.
  3. Maskot
    Maskot
    13
    Aug 7, 2013
    I have until Monday of next week, I did more research about the LED, it's very useless for what it advertises, I'm going to just be doing a flashing sequence of 6 LEDs with 2 sets, I'm sure I can find this online, I'll look into the 555 4017 configuration as well, thanks.
    EDIT: I've looked into the 555 4017 circuit, I'll be using that and it's no problem if there's a gap from the first to the sixth, I hope the local radioshack has them.
    SECOND EDIT: Radioshack doesn't carry the 4017 in store... I'll try to find a local supplier somewhere that can probably help me with it too.
  4. Fish4Fun
    Fish4Fun So long, and Thanks for all the Fish!
    464
    105
    Aug 27, 2013
Similar Threads
Loading...
