LED Powered Miniature Light Show
Discussion in 'LEDs and Optoelectronics' started by No6h, Feb 18, 2016.
  1. No6h
    No6h
    6
    Aug 6, 2015
    I'm about to start working on a miniature rock stage, with 3D printed instruments (hopefully). I also would like to incorporate an LED light show... There are a few pieces of inspiration, as well as things I would like to recreate. Here goes!
    My idea for colouring the stage was a bunch of RGB led, with a potentiometer attached to each colour, so i can mix the colours and make different colours.
    I have a bunch of super bright white LEDs in place of blinders for chorus sections of songs.
    (0:16)
    The only thing i'm missing is pattern lights.
    (0:20)
    (0:02)
  2. Martaine2005
    Martaine2005
    3,557
    967
    May 12, 2015
    Hi No6h,
    Your imagination and the effects you want are key!
    Personally, I would start with a cheap $2 chinese toy with flashing lights. Cannibalize it and run it from a 5v phone charger (assuming it runs on 3 or 4x1.5v). Batteries wont last 2 minutes in those toys!
    Example:
    These can be bought very cheaply from an open air market. Not online!!
    [​IMG]
    Martin
  3. No6h
    No6h
    6
    Aug 6, 2015
    what a great idea. I have this rubber ball with a whole bunch of leds in it, so i might look into that for something interesting. I kinda don't want to use Arduino, as I only have one.
  4. No6h
    No6h
    6
    Aug 6, 2015
    here is what i found. It has a very strong strobe effect, but when i put a cardboard tube around it as a basic diffuser, it made a very cool effect.
  5. No6h
    No6h
    6
    Aug 6, 2015
    In terms of RGB leds, do you have any experience with them? Originally I was considering using potentiometers to mix the colours, but now I think a rotary switch to select the colours with appropriate resistors on the terminals (2 pole 6 position) to select red, orange, yellow, green, blue and purple.
  6. No6h
    No6h
    6
    Aug 6, 2015
    would RGB be better or leds of other colours switching in and out...
