Dave said:
Another issue is that standard 5mm LED's, while they may 'go' for 100,000
hours, their light output degrades quite quickly- in the order of 30% after
9000 hours and this degradation continues past this time frame. Google
'LED degradation' for some 7,000,000 pages!
OzDave
www.rpc.com.au
Meh,so they lose 30% after more than a year,if you were to leave them on
24/7.If you only switch them on for 12 hours each night,that's two
years.(assuming turning them on/off doesn't shorten thier life
somehow.).Personally,I wouldn't much care if they went slightly dim,or
dead completely after 2 years,they only cost a few cents each!
I'm fond of the small CCFL tubes and inverters.I've salvaged a few from
old laptops,and flatbed scanners.They make great little area/work
lights,and most are 12Vdc input.(I think I have a couple that use other
voltages 15,and 24V I think.)They usually only draw a couple hundred
milliamps.(I think some of the larger ones I have draw around 275-300ma)
Plus,you can get the ones for adding to the case of your PC,etc. for
relativly cheap,and in lots of colors,styles,lengths,etc.
And also EL tape,and rope/cord..I'm sure that could make some
interesting night-lights.
Perhaps the neon kits for putting under cars? ;-)
