I have two different sets of white LED night lights, both bought from
costco. All of them worked quite well when new, but become noticeably dimmer
over the course of one to two years. Some are so dim they are useless as a
night light.
LEDs are supposed to last a long time. Could this be caused by overdriving
the LEDs? It's very disappointing.
Did the lights come with a guarantee of light output over time? If not,
that was a clue to lack of quality. If so, get them replaced.
Now I'm thinking of buying LED flood lights from hardware store eqivalent to
60W incandescent blub. Would they also become noticeably dimmer after a year
or two? If so, I'm not buying.
There are a lot of crappy things that are built with LEDs, poorly, and
at very poor lumens per watt, for sale to the uncritical masses that see
LED and look no further. If you avoid those, there's also some good
stuff coming on the market, and some stuff that might at least be worth
giving a sample item a try to see if it's any good yet. But you have to
be able to smell the pure crap and avoid it.
Aging is normal. How bad (or how much) is somewhat influenced by what
you buy. Inadequate cooling and/or overdriving the current will make it
worse, yes.
Two major-brand name not terribly cheap (well, one is actually somewhat
expensive) LEDs I have are guaranteed to produce at least 70% of rated
output at 5 years of age (or 50,000 hours). That would be noticeable,
but not (as I use them anyway) useless. The companies in question will
probably actually be around in 5 years, if the lights fail. Failure is
more likely to be a defective individual unit than a design flaw
affecting all units, if it does occur.
Chinese "night lights" from "company changes name every two weeks to
avoid liability for the junk they make" are a different story. Most are
crap from day one, and they certainly don't improve with age.
Likely the same with "flood lights" if they are house-brand or a name
you've never heard of, and don't have a 5 year or 50,000 hour guarantee.
House brand is better than unheard of if there is a guarantee, since the
hardware chain is likely to be around longer than a chimeric low-quality
company.
IMHO, if you are looking for a "flood light" (particularly an outdoor
one) and want LED, it's better to look at a fixture than a bulb. Both
the cooling and the throw of light are done better with a fixture that's
designed from the ground up as an LED fixture. But if you want an
outdoor fixture for sub-$100, I think all you're going to find at this
time and that price point is junk. Plenty of it, but it's junk.
One simple criteria (you may need to have a calculator handy, as it's
often not presented) is lumens per watt. If you stick to things that are
50 lumens per watt or better, you avoid a lot of the junk without having
to look too closely at it, or know much beyond "how many lumens" divided
by "how many watts"...
