Kamper Dave
- Mar 29, 2012
- 2
- Joined
- Mar 29, 2012
- Messages
- 2
LED lighting for a camper with 12dcV power:
Please, tell me if what I ended up doing will work. Do I need high wattage resistors?
We ordered two styles of 12dcV LED arrays from China for use in our camper. The first batch were basic 24 LED arrays with one 4 legged chip on the board. Reversing the 12 volt supply makes no difference, it lights either way. The problem is that they are very bright until the LED’s become hot enough to melt solder. I wired two in series but they are not bright enough that way. Since they were small and we needed more light, I wired two arrays in parallel and placed a 100 ohm resister in series to them both. They are bright enough and warm not hot. The resistor is very warm but holding at 140ºF. I measure 8.5dcV volts down from 12dcV. Without the resister in the supply line we draw 0.85dcA with the resistor 0.1dcA.
The second set of 12dcV LED arrays that we purchased contained 48 LED per array no other components on the circuit board. They came with adaptors to convert standard automotive light fixtures to these LED arrays as well as being backed with 3M double sided tape for easy installation. We installed one array and after one hour the array was still working but the double sided tape had shrunk and curled up and the back of the LEDs black where the adhesive burnt. So, I went back to the bench and wired a 100 ohm resistor in line same as above and with the same results as above.
Will this cobbling job work? Should I be using power resistors vs. carbon?
Thank you in advance for your help.
Kamper Dave
Kamper Dave
