led light bar
Discussion in 'Troubleshooting and Repair' started by haven't got a scooby, Oct 10, 2015.
  1. haven't got a scooby
    5
    Oct 10, 2015
    Hi everyone I'm a newbie to this
    I purchased a led light bar for my 4x4 off eBay I had it a week and it just stop working other than to led's either end of it any help much appreciated
    Photos on request
  2. Martaine2005
    Martaine2005
    2,673
    722
    May 12, 2015
    Hello clue,
    Not enough information to even guess.
    How many leds on the strip.
    What voltage is the strip.
    What strip is it (link).
    Where and how did you install it.
    4x4 taxed road vehicle or Radio controlled 4x4 car.
    See what I mean...
    Martin
  3. haven't got a scooby
    5
    Oct 10, 2015
    So there is 6 led's on a module it's on a suzuki jimny so 12volt battery at a guess installed into a relay then from there into a fuse holder and then onto car battery
  4. Martaine2005
    Martaine2005
    2,673
    722
    May 12, 2015
    Hi Clue,
    That first photo looks like the traces have broken.
    The solder blobs look real bad too from the + and - links.
    Have you got a meter to check continuity across those joints?
    Incidently, is there a wire at each end of the light bar or two from one end?
    Martin
    Arouse1973 likes this.
  5. haven't got a scooby
    5
    Oct 10, 2015
    Traces ? What are they and the wires come in from the end then connected in the middle
  6. Martaine2005
    Martaine2005
    2,673
    722
    May 12, 2015
    The traces are the pcb connections to all components.
    Yours look to have failed or broke!
    In other words, no connection from one point to another.
    Martin
  7. haven't got a scooby
    5
    Oct 10, 2015
    Oooo sorry I have no clue so are these fixable ?
  8. Martaine2005
    Martaine2005
    2,673
    722
    May 12, 2015
    Yes they are.
    But you will need a soldering iron to do it.
    It is basically to re-make the connection that has failed.
    Martin
  9. haven't got a scooby
    5
    Oct 10, 2015
    Well thank you for your help on this I will let u know how it goes it's covered in electrical grease aswell
    Martaine2005 likes this.
  10. Martaine2005
    Martaine2005
    2,673
    722
    May 12, 2015
    Just a side note Clue.
    It is rather difficult reading your posts without a full stop.
    Can you try and insert grammar if possible too?
    No offense, just makes reading your posts easier to help you.
    Martin
