williamsjp2004
- Dec 16, 2014
- 2
- Joined
- Dec 16, 2014
- Messages
- 2
I'm trying to build an LED light bar that runs off of 12V that I can turn a potentiometer to control the intensity. That's the easy part. The part that I'm running in to problems with is that I would like it to fade in one by one.
When LED 1 is lit to about 3 volts (I will be using 3 volts as my maximum for the LEDs, all LEDs will be the same), I would like LED 2 to begin lighting. After LED 2 is lit, LED 3 begins, and so on...
The only thing I have been able to figure out is connecting 12V to a pot. to a current limiting resistor, from the limiting resistor to an LED, from LED to BOTH the next LED and to a resistor connected to ground. The problem is, this works up to about 3 LEDs, then the rest (of a total of 7) don't light and if I apply enough power, the first LED fails under the load or course.
I'm hoping I explained that well enough. Basically I would kind of like to have a single equalizer bar that is controlled by a pot. instead of by sound. I'm trying to get as basic as possible but do know how to read schematics and can put together any circuit not using personally coded ICs.
Thank you in advance for the advice.
