LED flashing/beating heart help/advice
Discussion in 'LEDs and Optoelectronics' started by carebare47, Nov 13, 2010.
  1. carebare47
    carebare47
    66
    Oct 21, 2010
    Hello,
    I was thinking of making a LED heart (maybe three concentric heart shaped rings of LEDs) that flashes/pulses/dims (or other patterns) for my girlfriend. I was wondering what pattern to use and how I would go about creating something that will do that. I know a little about astable flip-flop circuits and have tried to use a 555 timer before (didn't succeed last time, but I have improved much since then). I was going to build the final design on strip board. I could make one that just alternates two series' of LEDs but I was hoping for something a little more complex. Any and all ideas are welcome =)
    Many thanks,
    Tom
  2. RAMSELECTRONICS
    RAMSELECTRONICS
    14
    Nov 4, 2010
    It's nice!
  3. carebare47
    carebare47
    66
    Oct 21, 2010
    Help with the 'circuitdiagram.net/flashing-heart-circuit' circuit!!
    Hello again,
    Firstly, thanks for the links. I decided on the http://circuitdiagram.net/flashing-heart-circuit.html one. I have constructed the circuit on a protoboard (but have used BFY51 transistors as it is rather difficult to find and 2N3643s near me. Will the BFY51 still work? It seemed similar enough). So far I have only put a few LEDs in (to see if the circuit works before I construct it on strip board). There is one LED coming from Q1 (which flashes just fine), and two each from Q2 & Q3 (Q2 LEDs flash, Q3 do not). I am not really sure what the dotted lines on the schematic mean. If I connect these dotted lines then LEDs from Q2 & Q3 flash at the same time. If I don't, then only LEDs from Q2 flash. The Q2 LEDs are flashing at a frequency of about 1Hz (didn't have a potentiometer for R9 so I used a fixed resistor and improvised with 4x 4.7uF capacitors in parallel for the capacitors between pin 1&3). Also, the LEDs from Q2 don't flash on and off, they flash from bright to dim(ish). Any ideas? Could someone please explain these dotted lines? ^_^
    Many thanks,
    Tom
  4. barathbushan
    barathbushan
    223
    Sep 26, 2009
    if you have a multimeter check the base of q2 and q3
  5. carebare47
    carebare47
    66
    Oct 21, 2010
    The bases of both were fine, but the actual Q3 transistor was not. Tested it with my multimeter and it wouldn't give a hFE reading. Still don't really understand the dotted lines though. Swapped it with a working one and all is good. Now to order masses of LEDs and start transferring it to strip board =)
    Many thanks,
    Tom
