Jeff Zimmerman
First a desciption of what I'm trying to do (sorry if it is
confusing):
I'm trying to make an LED driving circuit that will change (8) groups
of (8) LEDs (turn one group on and another off) whenever a beat is
detected. To drive the LEDs, I'm using (8) ULN2803's (darlington
arrays).
For the beat detection, I was thinking about using a LM3915 VU meter
chip, and the audio input is from an amp has a low pass filter at
about 150 HZ.
To change the groups of LEDs, I was going to use a 74393 dual 4 bit
binary counter, with it's clock signal connected to the highest output
of the 3915. There would also be a pull up resistor on the clock
input.
Now for the questions:
I tried this and it did work, but there were a couple of problems.
The first was that the output from the 3915 isn't steady, the counter
would count more than once for each beat.
Is it possible to clean this output up?
Also, if anyone has any suggestions on a better way to accomplish
this, I would greatly appreciate it.
Alittle extra info:
I have (4) 5 volt reg's, 3 are used to drive the LEDs (20 leds per
regulator), a .1 ohm 5w resistor is placed in series with the
regulator to limit the current.
confusing):
arrays).
about 150 HZ.
input.
Alittle extra info:
