Led dimming help.
Discussion in 'LEDs and Optoelectronics' started by AGLite, Mar 31, 2012.
  1. AGLite
    AGLite
    35
    Feb 19, 2012
    Hi guys,
    I have a lighting controller that I recently put two pre-built LED bars in. The bars have 16 blue LEDs in each and run off of 12 volts. when I put a pot. in the power in it dims very bad and 4 of the LEDs are all that dim the rest turn off. I don't really care about dimming. I just want them to turn on smoother, so what I want is when i turn on the toggle they slowly fade to full brightness. I appreciate all the help i can get.
    Austin.
  2. (*steve*)
    25,497
    2,839
    You would need to get a PWM controller to do this.
    Here is a commercial unit (no doubt you can get them more locally).
    And here is a description of how they work so you could make your own if you wanted to.
  3. AGLite
    AGLite
    35
    Feb 19, 2012
    so if i say hook the dimmer up and set it to full brightness. and then turn on the toggle, they will slowly fade up?
  4. (*steve*)
    25,497
    2,839
    No, you wind the brightness up on the controller and the brightness goes up.
  5. AGLite
    AGLite
    35
    Feb 19, 2012
    do u know how to make it do that
  6. (*steve*)
    25,497
    2,839
    Have a look at a constant current source using an op-amp to compare the voltage across a current sense resistor with a reference voltage.
    Then get your reference voltage from a voltage divider.
    Place a capacitor across your voltage reference and the constant current source will slowly (depending on the size of the resistor and the capacitor) ramp up to a maximum brightness.
    It may require some tweaking and it may be best if your load does not require a current source (otherwise your reference voltage will need to be regulated then divided)
