LED Dimmer suited for task?
Discussion in 'Troubleshooting and Repair' started by bushtech, Dec 28, 2017.
  1. bushtech
    bushtech
    1,013
    157
    Sep 13, 2016
    I bought this dimmer and the 3 led lights that it's meant to drive from an electronics place.
    Worked fine for about 10 hours after which I could hear some crackling in the dimmer, upon investigation I could see some sparking in the pot.
    The heatsinked transistor is a BT137. The lights are 240V AC 6W dimmable. The pot is 500K. Markings on the cap CY250 and 104J1.
    Is this dimmer man enough for the job or have I been sold a lemon?
  2. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    Where in the pot?
    It looks like a very basic DIAC/TRIAC arrangement for dimming but doesn't seem to have any snubber components. Equally the track clearances between screw terminals is ABYSMAL !!! Dangerous etc. You may have heard arcing across them.
    bushtech likes this.
  3. 73's de Edd
    73's de Edd
    3,063
    1,299
    Aug 21, 2015
  4. bushtech
    bushtech
    1,013
    157
    Sep 13, 2016
    Thanks kellys_eye
    Reinstalled the dimmer to check but couldn't reproduce the arcing, whatever is causing it has probably died.
    Checking the pot: (in situ)
    Note: DMM in 2M range
    Left and centre pin (as per above photo): 0Ω
    Left and right pin: 0.8MΩ from off click right through to max
    Right and centre pin: 0.8MΩ from off click right through to max
    What is the best way to sort this? Can this dimmer be made to work properly with some modifications or would it be better to build a dimmer using a 555 or some other design?
  5. 73's de Edd
    73's de Edd
    3,063
    1,299
    Aug 21, 2015
    Sir bushtech . . . . .
    You say . . .
    Whereas, you are able to get much lower ohmmage at the other Left limit . . .akin to . . . .
    Making one wonder if your pot has an end of limit burnt area out at about Right extreme ?
  6. bushtech
    bushtech
    1,013
    157
    Sep 13, 2016
    Thanks St Edd
    Those readings persist even with the pot clicked off:confused: I think it's history.
    Just need to know where to go from here as per Post #4
  7. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    LED dimmer ?
    Not so ,it is a continuous phase control dimmer
    mainly use for A.C. halogen and incandescent bulbs light control.
    While a LED dimmer should be a DC current control circuit.
  8. bushtech
    bushtech
    1,013
    157
    Sep 13, 2016
    Thanks Dorke
    So they sold me the wrong thing?
  9. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    They did,If you are trying to control a "pure LED" lamp .
    Please post the data sheet of the your lamp.
    In any case it shouldn't have died,the LED would probably blow though...
  10. bushtech
    bushtech
    1,013
    157
    Sep 13, 2016
    Thanks dorke. Led's still working. Wired a on/off switch in there ilo the dimmer.Data sheet is one of the PRC's usual things
    This forum's resources area has an led section, thanks *steve*. It does list some dimmers and I have some 555's. But looking at the link: http://www.reuk.co.uk/wordpress/lighting/led-dimmer-circuit/ at the bottom of the page they state that it didn't work with MR16 leds and this is what I have, albeit mine are 240V and they are using 12V led's.
    So a bit stuck here. Looking for the correct way to dim these critters
  11. bushtech
    bushtech
    1,013
    157
    Sep 13, 2016
  12. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    Look at section d)
    Is the one you have a dimmable bulb?
  13. bushtech
    bushtech
    1,013
    157
    Sep 13, 2016
    Thanks dorke
    Yes they are dimmable. Light fitting takes 3 bulbs as in first photo, each 6W
  14. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    This isn't a very safe device,it uses no isolation to drive the 555 timer from the mains.
    If you use it the least would be for the outer parts(frame/pot shaft and knob) to be well isolated (plastic).
  15. bushtech
    bushtech
    1,013
    157
    Sep 13, 2016
    The switch that it will be mounted into is well insulated including the plastic knob. Can I stick an opto isolator in there? Ooops I see there is one in there. Is there a better design somewhere?
  16. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    Isolation isn't a specific requirement if, as mentioned, the circuit is built into an insulated enclosure and the pot shaft is likewise insulated.
    The 'important' part would be the 0.33μF capacitor which should be X2 class and have a 'bleed' resistor (say 330k) across it.
  17. bushtech
    bushtech
    1,013
    157
    Sep 13, 2016
    Thanks kellys_eye. Had to go and google X2 cap- had never heard of it. This is what my preferred supplier has: https://www.mantech.co.za/Stock.aspx?Query=0.33uf+x2+capsand
    I see the highest they have is 275V. Will that do or do I need 400V?
    Also never dealt with opto couplers and when the designer says "any optocoupler" I get miffed.
    Here is a selection from my preferred supplier again: (all 327 of them): https://www.mantech.co.za/Stock.aspx?Query=opto+couplerand.
    What am I looking for? Any optocoupler wtf!
    If this is a good design then I am going to build this
  18. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    Check the data sheet - 275V AC but 560V DC - there are others in the range too.
  19. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    This is the kind of stuff you better buy rather than make yourself.
    kellys_eye and bushtech like this.
  20. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    But not from the same supplier you bought the original device.........
