LED Dimmer problem
Discussion in 'Electronic Basics' started by Allen Bong, Dec 21, 2005.
  1. Allen Bong
    Allen Bong Guest
    Hi Group,
    My friend designed a circuit to light up an LED when a switch is
    pressed. The led lighted would be duplicated to another identical
    circuit board via RS232 link (2400 b/s). When an LED is lighted, the
    LED would flash at 1 Hz interval. One would acknowledge by pressing
    the corresponding switch on the board. Once acknowledged, the LED
    would be on permanently until another switch is pressed.
    The switches and LED are arranged as 2 rows of 12 . Only one switch is
    allowed per row so there can only be 2 LED lighted and 2 LED in
    flashing condition.
    After he completed the circuit and fabricated the PCB, he wanted to add
    a dimmer so he could control the brightness of all the LEDs (the
    circuit is used in a boat). As you can see from the circuit below, he
    turned the LED on by sourcing the LEDs and all the LEDs were common at
    ground through 220 ohm resistors. So what I did is gathering all the
    cathods and connected them to the drain of a MOSFET BUZ71A. This
    worked fine when the brightness is high. But when the LEDs were
    dimmed, the permanent lighted LED danced with the flashing LEDs and I
    couldn't find a simple solution to solve it.
    If instead he had sinked the current to switch on the LEDs, I would
    have combined all the anodes of the LEDs and connected them to a LM317
    and supplying 2V to 5V to the LEDs. But that would be major work for
    him and also rewriting the PIC software.
    Can someone help?
    | PIC |
    VCC VCC VCC
    pulsed dc at 1Hz | | |
    | |LED |LED |LED
    V -> V -> V -> V ->
    -LED - - -
    VCC | | | |
    .-. | |220 | |220| |220| |220
    47K| | '-' '-' '-' '-'
    '-' o-----------+-----+------
    | |D
    .-. 100 ||<- MOSFET
    50K pot| |<---|___|--||-+
    | | |S
    | GND
    | | DIMMER CIRCUIT
    150K | |
    GND
    (created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
    Allen Bong
  2. Ben Jackson
    Ben Jackson Guest
    Easiest way to do this is to make the PIC drive a varying duty cycle
    on the LEDs (eg you are already scanning an array, just pause between
    scans to get dimmer output).
    Barring that, keep your FET, but drive it (to saturation, not with the
    pot) with the PIC using an PWM output to get the same effect.
    If nothing is free on the PIC, drive the FET with a 555 with a pot
    controlled duty cycle.
  3. Richard
    Richard Guest
    How about switching in one or more resistors in your cathode circuit? Using
    a 3-position switch, you could add 100, 220, and 1000 ohms to progressively
    dim the LEDs. If a mechanical switch won't work, how about a pushbutton and
    using the PIC to drive 3 electronic switches to switch the resistors into
    the circuit?
    Richard
  4. Feed the FET with a squarewave (freq high enough to stop flicker), vary
    the mark/space ratio to give you brigtness control. A simple 555 will do
    this.
    TCM
  5. Allen Bong
    Allen Bong Guest
    The LEDs are not connected as a matrix but one LED per port pin. The
    switch is directly wired to the same port pin as the LED (I will submit
    another post regarding this design) so this method is not applicable
    here.
    Though there are some ports not used, but the 2 pwm ports were
    allocated for the SW and LED. I've asked him if he could spare me one
    pwm port and his answer is negative. Guess his software is not that
    modular. So another NO here.
    This option seems to be the most convenient for me to implement. The
    dimmer will be mounted on a small PCB and glue to the main PCB using
    hot glue. 555s are readily available but I have to get a suitable
    circuit and do some breadboarding before I commit to PCB.
    Thank you very much for your feedback and your ideas really start me
    thinking.
    Merry Christmas & Happy New Year!!!!
    Allen
  6. Allen Bong
    Allen Bong Guest
    Hmmm... a 3-position 24-pole switch would cost a fortune. And I think
    one can only find these parts in test gears like o-scopes and frequency
    counters.
    You mean electronic switches like 4066? 24 LED * 3 / 4 =18 pieces of
    4066. That would occupy too much board space.
    Thanks for your inovative idea anyway.
    Allen
  7. Allen Bong
    Allen Bong Guest
    do
    this.
    TCM
    This is the same idea suggested by Ben Jackson (refer option#3) and I
    am going to try this out.
    Thanks and regards.
    Allen
  8. Richard
    Richard Guest
    If you have already gathered all the cathodes ("So what I did is gathering
    all the
    cathods and connected them to the drain of a MOSFET BUZ71A"), you would
    only need to connect that gathered connection to the the wiper on the swtch
    instead of the MOSFET. Connect three differenct value resistors to ground
    off the switch positions. Alternatively, three optical switches (for
    example, PVA3324) may also work (that is what we used as a dimmer circuit on
    a piece of equipment where we had to simultaneously dim 17 LEDs, so it may
    work for you). The components were all surface mount, so not much space
    required.
  9. That would achieve a result no different from the FET/POT - the modulated
    LED would affect the current in the others.
    PWM is the easy way to go, whether by a 555 or extra code in the PIC. If
    this is a one-off I'd go the 555 route for simplicity.
    TCM
  10. Bill Bowden
    Bill Bowden Guest
  11. Allen,
    If you have two groups of LEDs, a flashing group and a non-flashing one, you
    can control them separately by using a dual pot and two mosfets.
    petrus bitbyter
  12. Allen Bong
    Allen Bong Guest
    modulated
    If
    I totally agree with you. But it is very educative to learn something
    new called PVA3324 optical switch too. Tks.
    Allen
  13. Allen Bong
    Allen Bong Guest
    You can get a wide duty cycle adjustment (5% to 95%) using an extra
    diode with a 555 oscillator. Example is here titled 12 volt lamp
    dimmer, using a pot.
    http://ourworld.compuserve.com/homepages/Bill_Bowden/page6.htm#dimmer...
    -Bill
    This is exactly what I'd been looking for. The LM555 datasheet for
    PWM schematics is rather incomplete.
    Thanks very much.
    Allen
  14. Allen Bong
    Allen Bong Guest
    one, you
    petrus bitbyter
    I am sorry I didn't explain the circuit very well and the schematic was
    rather vague. The fact was that all 24 LEDs were connected to a port
    pin each on the 16F877 but arranged as 2 rows of 12 on the front panel
    only. We didn't use scanning mathod to light the LEDs and they were
    not connected as 2 by 12 matrix.
    Tks,
    Allen
  15. Bob Monsen
    Bob Monsen Guest
    You claim that the fixed LEDs are pulsing at 1Hz? That is probably because
    the mosfet is being used as a resistor. In order to dim the LEDs, you need
    to set the resistance with the gate voltage. Sadly, this is just
    the same as using a pot, meaning that the pulsing LED changes the
    current through the resistor, changing the voltage at the other
    LEDs, causing your flash.
    The other problem with the circuit is that the range of adjustment is
    going to be very fine, with a particular point that causes the brightness
    to jump.
    You can fix both of these problems by using a follower configuration
    instead of the common source amplifier. Replace the MOSFET with a PNP
    bipolar transistor. Then, the voltage at the cathodes will vary much less
    with the flashing LED. The voltage at the cathodes will be adjustable
    between 0.8V and 5V. Use a 1k pot, and dump the other resistors...
    Vcc-----o-------- To Vcc on PIC
    \ .--to cathodes ->
    GND-----o--------o
    One thing you might not like about this is that your cathodes will always
    have at least 0.7V on them, due to the Vbe of the transistor. If this is a
    real problem, then you can fix it by using an NPN transistor in a buffer
    configuration with some PNP bipolar transistors:
    VCC-----o--------o---------------o-----o-----.
    | | pulsed | | |
    | | |LED |LED |LED |LED
    | | V -> V -> V -> V ->
    | 100 .-. .-. .-. .-.
    | .--o--. | |220| |220| |220| |220
    .-. e e | | | |
    50K pot| |<--b PNP b-----o-----+-----+------
    | | c c |
    | | | c
    | o-----)-----b NPN
    | | | e
    | 10k 10k |
    GND-----o-----o-----o------'
    While the circuit is far more complex than the alternatives above, it will
    allow you to set the voltage at the cathodes far better than your
    amplifier scheme, allow voltages down to nearly 0 allowing full
    brightness, and will prevent almost all of the crosstalk between the LEDs.
    Regards,
    Bob Monsen
    Patricia's nature was an endless wish to make other people as happy as
    she was.
  16. Allen Bong
    Allen Bong Guest
    -Bill
    I have constructed your circuit on a strip board and tested with 8
    LEDs. It works on my first trial.
    The brightness disappeared after turning 40% on the pot and no flicker
    was noticeable. I have to trim the top 1K resistor higher so that the
    brightness only disappears until the pot has reached the end.
    The diode doesn't have to be 1n400x. I substituted it with a 1n4148
    and it also worked. It was magical to see how the duty cycle drops to
    50% if the diode was disconnected.
    Thanks for your great circuit!
    Allen
  17. Allen Bong
    Allen Bong Guest
    Yes, that's right. The reason I didn't use a pot was because we can
    find a wire-wound
    50 ohm pot in the town we live in. The same reason for using BUZ71A
    (7A mosfet) as
    I can't find anything smaller than that.
    \ .--to cathodes ->
    GND-----o--------o
    Didn't try out this one but as you said the drop across the CE is 0.8V
    which is unacceptable.
    The same reason I turned to MOSFET which has a drop of <0.1V when fully
    turned ON.
    | | pulsed | | |
    | | |LED |LED |LED |LED
    | | V -> V -> V -> V ->
    | 100 .-. .-. .-. .-.
    .-. e e | | | |
    | | c c |
    | | | c
    | o-----)-----b NPN (Q3)
    | | | e
    | 10k 10k |
    Yes, I tried this circuit and it works well. I use 2n2907 for the 2
    PNP but different NPNs
    for Q3 have different results.
    I took 2 voltages across CE of Q3. One when Q3 is fully conducting and
    one when the LEDs are dimmed.
    The results are as follows:
    Q3 fully ON LEDs
    dimmed
    2n3019 1.44V 2.13 -
    2.15V
    2n3053 0.48V 2.16 -
    2.19V
    TIP31 0.1V 2.26
    - 2.29V
    Only TIP31 can get almost 0V as you mentioned. I'll also tried
    Darlington NPN (2SD768) tomorrow as it is getting too
    late now. Does the gain of the PNP matters? There is about 100mA
    flowing through Q3 when all the LEDs
    were ON at startup. A TIP31 would be overkill.
    Cheers.
    Allen Bong
  18. Bob Monsen
    Bob Monsen Guest
    OK. However, adjusting the values of the 220 ohm resistors in the original
    circuit can compensate for this problem.
    Your table looks wrong. The 2N3019 has a Vce(sat) of between 0.1 and 0.5V,
    so there is probably something wrong with the transistor, perhaps the beta
    has been compromised, or you have it in backwards. If not, then you might
    want to decrease the size of the pot to see what happens (if you are
    curious). There might be some edge case in the circuit that you are
    falling into with this particular transistor.
    You can use a 2N4401 at the current your require, so I would go with
    that, since it has a fairly small Vce(sat). Also, I would increase
    the 100 ohm common resistor to 1k. You could probably go up to 4.7k with
    no problem. It was set to 100 because I didn't know how much current
    your Q3 would need to pass. Having it that low can cause temperature
    differences on the transistor, leading to inaccuracy (not that it is very
    accurate anyway...;)
    Regards,
    Bob Monsen
    It would be a waste of breath to tell a man who believes in guns that
    you've got something better.
  19. Allen Bong
    Allen Bong Guest
    original
    This at least I'll try on a breadboard.
    0.5V,
    beta
    might
    To be honest, I didnt try the circuit on the real thing, but just on a
    simulator. I was also surprised when I see the results as well. But
    when I short the BC of 2n3019, the Vce did not drop vigorously as I was
    expecting. It just dropped merely 0.15V to 1.29V.
    Anyway I am going to try out the circuit below on various transistors
    that I have .
    VCC -------
    | | o
    | o \o
    | 100| | | |1000
    10k | |<----| | |
    | | | o-----o---
    | ------| (_/_)
    .-. |> \_/
    100| | | |
    | GND GND
    GND
    to see if the simulator is lying to me.
    The datasheet also stated that to get Vce(sat) on 2n3019, you need
    Ic=150mA and Ib=15mA. I put an mA meter on the simulator and the
    current is only 58+mA through Q3.
    with
    very
    I have only 1 or 2 2n4401 but plenty of 2n3019 and 2n4033. So I would
    give the 2n4401 a try this weekend to construct it on breadboard.
    On the simulator, changing the pot resistance down to 10K doesn't
    change anything with the 3019. I also change the 2 10K resistors to
    4.7K and it got worse. Changing the 100 ohm to 1k didn't have much
    influence on the 3019 too.
    Cheers and Merry Christmas.......
    Allen Bong
  20. Allen Bong
    Allen Bong Guest
    Hi Bob,
    0.5V,
    beta
    might
    After buying some 2N4401 & BC337 yesterday I tried out the circuit on a
    breadboard and
    have the results shown as below:
    Q3 fully ON LEDs dimmed
    2n3019 0.12-0.18V 2.98 - 3.07V
    2n4401 0.13-3.20V 3.05 - 3.12V
    BC337 0 -0.02 2.91 - 2.97V
    All 3 transistors worked well in the circuit. I also measured the Vbe
    when Q3 was
    fully turned ON and I got the values of 0.73-0.74 volts for all the 3
    Tr. Can't
    understand why it differed so much on the simulator. I'm going to down
    another one to
    try out the circuit again!
    with no problem. It was set to 100 because I didn't know how much
    current
    very accurate anyway...;)
    I thought that I still have some 2N4401 but when I checked into my
    spare part box, I
    noticed that they were actually 2N4403. After getting some new 2N4401,
    the circuit
    finally worked as it should be.
    In the datasheet, the Vce(sat) for 2N3019 was measured at Ic=150mA when
    Ib=15mA. But I
    can Q3 to saturate at a much lower current. Was the Vce(sat)
    controlled by Ib or Vbe?
    Thanks so much for helping me to get my circuit working. Not
    forgetting Bill Bowden's 555 PWM and others who posted.
    Best regards.
    Allen Bong
