I have a buck type LED driver that adjusts voltage output depending on whether I wire LED's in series or parallel. If i wire in parallel the voltage output is always 3.2V with a constant current output of 350mA, but if I wire them in series the voltage increases by 3.2V per LED. The intensity of the LED's seem rather bright and i am thinking if there is any way to reduce the intensity? maybe by adding a resistor of some kind on the output positive wire of the driver before it connects to the parallel LED's?
If so what kind of resistor would be recommended?
thanks
thanks
