I am interested in building an LED array with about 40 LEDs. They take
3.3 volts at 20mA.
Does it make sense to make 20 arrays of 2 in series with a 150 ohm
resistor, and connect all of those in parallel to a 9 volt battery?
In this way they will pull 400 mA from the battery. I don't think this
is the best solution as it will deplete my 9v battery too quickly.
I am a novice so any help is greatly appreciated!
Thanks! Actually the current will be a little less:
I = (Vsupply - Vled)/R;
therefore I = (9-6.6)/150 so I = .016
20 strings would use 320 mA.
But it doesn't make sense in any event, because you
won't get much life out of a wimpy 9V battery. I'd
recommend using a "wall wart" supply instead. There
are many alternatives - here's three:
| [LED] [LED] [LED] [LED] [LED]
| 12V +|---+ [LED] [LED] [LED] [LED] [LED]
| Wall | | | | | |
| Wart | [LED] [LED] [LED] | |
| -|---+ | | | [270R][270R]
------ | [110R][110R] [110R] | |
DCTX-1216 | | | | | |
The part number is from Allelectronics for $6.75http://
www.allelectronics.com/
That's 12 strings of 3 LEDs with a 110 ohm current
limiting resistor for ~ 19 mA and 2 strigs of 2 LEDs
with 270 ohm for ~ 20 mA. Total current is ~ 270 ma.
You could replace the wall wart with a 12 volt gel cell
for portable operation.
Here's another, with 10 strings of 4 LEDS, each
with a 150 ohm resistor:
| [LED] [LED] [LED]
| 16V +|---+ [LED] [LED] [LED]
| Wall | | | |
------ | [LED] [LED] [LED]
DCTX-161 | | | |
| [150R][150R] [150R]
If you *must* use 9V batteries, how about three of
them in series? Then you would have 5 strings of
8 leds, each string in series with a 33 ohm resistor,
with a total current draw of ~ 91 mA. You would
get more life this way than you would if you put
three batteries in parallel (which is not a great
idea for other reasons) owing to the lower discharge
rate.
Ed
