Lecroy 9400
Discussion in 'Electronic Equipment' started by [email protected], Mar 28, 2005.
  1. Guest
    Hi
    After 3 years my Lecroy 9400 has died. It no longer responds to the
    front panel or GPIB. Everything still works but the settings are stuck
    and can`t be changed. There is a red LED glowing on the main board
    which I guess is a fault indication. My gut reaction is that a clock
    has stopped oscillating but where to start???
    Any help appreciated.
  2. kishikawa
    kishikawa Guest
    Hellow Nick,
    I have Lecroy 9450A having some trouble.
    But most of time it works properly.
    There is a red LED on front panel interface board(main board?).
    Red LED is glowing,it blinks when changing front panel settings.
    Maybe LED glowing means not fault.
    I guess clock is not setted properly maybe PLL circuit is in problem.
    So cpu is waiting until clock setted signal.
    If you have another Oscilloscope.
    Check clock out signals in rear panel.
    My Oscilloscope does not output any signals when troubled.
    But when Oscilloscope works well there are clock out signals.
    Your trouble is very similar to my trouble.
    Most of my trouble is not triggered.
    But rarely I can not change front panel setting as your trouble.
    I am shooting this trouble.
    But I have not schematic diagrams,service manuals.
    Have you any advice?
    Thank you Kishikawa
  3. Guest
    Many thanks for the response.
    I see what you`re getting at. Where are you looking for signals on the
    rear panel?? At one of the RS ports or the GPIB??
    Had a poke around with another scope and find that both crystals are
    operating....although did `nt know there were PLLs on board.
    Thanks for the tip on that LED....I`m certain it does n`t
    blink....maybe confirmation that front panel signals are not getting
    through.
    A schematic is the answer I think.
    Nick
  4. kishikawa
    kishikawa Guest
    Hi Nick,
    Sorry I have not Lecroy 9400.
    Lecroy 9450A has clock out one of 4 BNC connector in rear panel.
    I think 9400 has clock out too, Sorry.
    My 9450A has clock-out-connector marked J6 in trigger-board.
    I am looking for PLL too.
    I think it must be near 100MHz crystal osc circuit.
    I have not schematic.I check IC name and pin-layout and pcb circuits.
    I think front panel signals are get by cpu.
    It is difficult both signal are wrong.
    So I think cpu is waiting the end of clock locked-signal.
    thank you Kishikawa
  5. kishikawa
    kishikawa Guest
    Hi Nick.
    I maybe fixed LeCroy 9450A Oscilloscope intermittent problems.
    1.100MHz Xtal is poor ----> change to 100MHz Xtal OSC.
    2.ECL power supply is -3.6V ----> correct to -5.0V.
    Most of time it supply -5.0V.
    I found it drop to -3.6V when LeCroy 9450A is not work fine.
    Variable resister for voltage adjustment in power supply unit is bad.
    Nick Check power supply voltages.
    -15V,+15V,-5V,+5V is correct or not .
    Thank you Kishikawa
