Lebelle 202 La Exp moving-message LED sign
Discussion in 'Troubleshooting and Repair' started by Upcman74, Feb 18, 2011.
  1. Upcman74
    Upcman74
    Feb 18, 2011
    Hello, I have a Labelle moving-message LED sign ( model 202 LA Exp) and in need of the power suppy and IR remote, I have tried to check with the company ( Display Sciences Group ) but looks like they are no logner in business, So I am reaching out to see if any has or carries the parts I need to get it up and running.
    thank you
  2. (*steve*)
    25,158
    2,676
    The power supply is probably the easy part. If you know the voltage and current requirements (and the polarity/type of the connector) then you will probably be able to find or trivially modify something.
    The remote control is likely to be a s stumbling block. I doubt whether anything other that an original part would work (it's *probably* a highly custom device)
