Learning Unijuctions
Discussion in 'General Electronics Discussion' started by JTSharkAttack, Feb 26, 2017.
  1. JTSharkAttack
    JTSharkAttack
    Feb 26, 2017
    So I've been learning how to make electronics lately with a book called Make: Electronics. In "Experiment 11", there is a project teaching you how unijunction transistors work, as seen below. I assembled the circuit and plugged it in. The light quickly blinked once, then remained dark again. After some testing, I realized the capacitor wasn't discharging. I replaced all the parts and moved the circuit on a different location on the breadboard, but nothing changed. Is there a flaw in the design, or something I'm doing? If so, what is it? Thanks
    [mod edited: sorted out images]
  2. BobK
    7,682
    1,686
    I can only say check all the connections and especially the pinout on the UJT.
  3. davenn
    davenn Moderator
    13,617
    1,881
    C1 isn't in the correct place ... it isn't doing anything where it is
    nor is R3
    compare your board layout with the one shown in the second image
  4. Bluejets
    Bluejets
    4,150
    878
    Oct 5, 2014
    C1 looks right to me but R3 definetely not correct.
  5. davenn
    davenn Moderator
    13,617
    1,881
    maybe the angle of the photo fooled me ;)
    but I cannot tell if the + and - terminals of the cap are going to the right places ??
  6. Bluejets
    Bluejets
    4,150
    878
    Oct 5, 2014
    True.....I did notice that also.
  7. CDRIVE
    4,960
    648
    May 8, 2012
    Where did the schematic go? Anyway I didn't like the way it was drawn so I was going to redraw it. That's when I discovered I didn't have a 2N6027 in my library. Actually I found I didn't have any UJT's or PUT's at all. I didn't even have a symbol for them. So I downloaded a spice model for it and drew a symbol to go along with the spice code.
    Note that I couldn't get it to oscillate with R1=470K so I lowered it to 220K. There was too much A-G leakage for the 470K to overcome.
    Chris
    Arouse1973 likes this.
  8. davenn
    davenn Moderator
    13,617
    1,881
    it's still there ... as are the other images
  9. CDRIVE
    4,960
    648
    May 8, 2012
    Huh, I guess the page didn't load correctly when I posted that because, as you say, it's still there... now.
    BTW, if the spice model is accurate I don't see enough C1 discharge current through the PUT to light a LED. The datasheet includes an astable example but they drive the LED with an SCR gated by the PUT.
    Chris
  10. BobK
    7,682
    1,686
    Look at where you are measuring current. There should be a large pulse of current through the LED when the UJT fires seeing as the capacitor discharges very rapidly.
  11. CDRIVE
    4,960
    648
    May 8, 2012
    Yes Bob, that was a very lame mistake.
    Chris
  12. CDRIVE
    4,960
    648
    May 8, 2012
    I guess after a goof like that I should post a corrected schematic and plot. I added R4 to limit the LED current and stretch C1 discharge time a bit.
    Chris
    duke37 likes this.
  13. BobK
    7,682
    1,686
    Nice. I guess you would call that a spike.
  14. CDRIVE
    4,960
    648
    May 8, 2012
    Yes, it certainly is a spike. I guess with only 2uF one should expect a brief pulse. It could be a handy pulse source for someone playing with time domain reflectometry. I wonder where the OP went?
    Chris
