robertgzzzt
- Jun 26, 2013
- 98
- Joined
- Jun 26, 2013
- Messages
- 98
I thought the whole idea with the ZIF socket was so that one could place a "blank" MCU on the programmer, then program it and remove it for use in another project. I actually chose it because it had the ZIF socket (and the ICSP port).
What I'm wanting to do is program the chips for use inside the models I build. I understand I would need to use the ICSP for programming SMD PICs that I've already pre-soldered to a board, as apparently there is no "slave" device for programming an SMD off-board, but for "through hole" PICs, can I not program those in the ZIF socket?
You mentioned earlier about creating ICP support on my project boards, so I could "update" the programming at a later time. I seriously doubt if there will ever be any need for updating. The lights in a particular model blink at a certain rate. All the chip has to do is blink those lights, forever, until it kicks the bucket.
Since I do not need to learn C++, in your opinion, which programming language should I learn?
