P
Phil Allison
"Jeff Liebermann"
"Phil Allison"
( delete drivel)
** Nonsense - the x-ray attenuation factor of thin Fe-Ni alloy is small.
** Wiki disagrees.
You got a cite for that ?
** Maybe so, but the face glass is way thicker.
** You must be desperate to use survey crapology as evidence.
** Irrelevant to the point - fool.
** When ???
It ain't changed.
...... Phil
"Phil Allison"
( delete drivel)
The metal CRT shadow mask is fairly impervious to x-rays.
What
electrons go through the holes in the shadow mask to light up the
phosphor dots, do not produce x-rays.
** Wiki disagrees.
Most travel backwards (reflected) which is why the funnel of the CRT
has much more lead in it than the screen.
See appendix B at:
<http://www.eiae.org/chemicals/files/EIA_CRT_5-01.pdf>
The shadow mask is made from Invar for mechanical stability.
When I was young (and stupid),
** When ???
It ain't changed.
...... Phil
