Z
Zach Zaborny
Hello,
I have two 12v 10Ah lead acid batteries that an electric scooter runs on.
I lost the original charger and have been trying to use a car battery
charger I had laying around. When doing each battery individually, they
charge normally. However, I tried doing both batteries (in parallel), one
started "bulging." Also, the bulging battery was very hot after charging,
which may be the cause of the bulging (plastic + high temps = not
good.) But the other battery was fine.
The charger is rated 8A @ 12/6V. It's built-in ammeter says that when
I put both batteries on in parallel, only about 7A is drawn; if that helps.
The charger is supposed to shut off when they are done charging, but
they never "charge" until they no longer draw any current. The lowest
the ammeter goes is 2A when they are on there. I have no idea if this is
normal.
What's going on here?
Zach
normal.
Zach
