LDO DC/DC Converter
Discussion in 'Electronic Design' started by [email protected], Mar 9, 2007.
  1. Guest
    Need a little help here. I am looking for a LDO DC/DC Converter. I
    have 7.5V input, looking for 5V output. Total current output needs to
    be upwards of 1A. Power consumption is critical and must be as low as
    possible since the 7.5V is from batteries. For this reason I have had
    a hard time finding an appropriate part. Any ideas?
    Cheers,
    Mike
  2. Dear friend :
    It is my fortunate writing to you . you will discover this is a wealth
    accumulation place.
    The website of our company is http://www.china-powerseller.com
    We are a big agent for Laptop
    Mobile Phone\Digital Camera\CDJ\DJM\Apple Ipod\PSP\VEDEO GAMES
    \Television\GPS\Telescope in CHINA .
    All of our commodities is the most advanced quality but lowest price.
    we also have the
    safest and most
    convenient transaction way to guarante the transaction arries on
    normally .
    looking forward to your coorporation and cause all of us both to
    profit.
    you can contact us by Email:china.seller#hotmail.com
    MSN: china.seller#hotmail.com
    best wishes!
    your sincerely
    MSN/Email:
  3. If power consumption is critical, you need a step-down (buck) switching
    regulator. Don't look for "low dropout" parts because that concept only
    makes sense for linear regulators.
    There are scores of ICs that can do what you want. Linear Technology's
    is a website you might want to start at.
    robert
  4. Right. Under "dropout" conditions the switch in an ideal buck
    regulator simply stays on all the time. Assuming it's a MOSFET,
    the value of Rds(on) for the gate-drive condition at the input
    dropout voltage will determine the input-output voltage drop.
    You can select a larger MOSFET to reduce the drop if you wish.
    If the pass-switch is a BJT, its saturation voltage at the load
    current will determine the dropout voltage. Some regulators use
    up a small additional drop for a current-sensing function.
    As well as all the other usual suspects.
  5. mpm
    mpm Guest
    Take a look at the National Semiconductor LM2575 (1-Amp)
    or the LM2576 (3-Amp)
    I've used the 2575. (9-pin TO-220 package)
    It requires an inductor, a Shottkey diode, and input/output caps.
    So you're looking at a 5-component solution if you go that route.
    My guess is the 2576 requires a pass transistor, but I don't know that
    for certain.
    Good luck.
    -mpm
