lcd tft panel sharp
Discussion in 'Electronic Repair' started by fingaz22, Nov 28, 2006.
  1. fingaz22
    fingaz22 Guest
    sharp flat panel tft lcd model # lm80c032 i'm tring to take a
    composite video signal say from a dvd player and turn it into a rgb
    datastream or something this flat panel tft i have can use to
    reproduce.
    the panel has a 31 pin connector on the back of it and 16 of those pins
    are for the rgb, 4 for each ,making up the 12 bit monitor that it is, 2
    for the horizontal & vertical sync signals , 1 for the clock signal , 1
    to settle the horizontal display position and a few for power & grds.
    the others are test pins.
    so looking for a convertor or what i would need to do to accopmlish
    this project. thank you very much for your time.
