lcd tft panel sharp model # lq9d161
Discussion in 'Electronic Components' started by fingaz22, Nov 28, 2006.
  1. fingaz22
    fingaz22 Guest
    i'm tring to take a composite video signal say from a dvd player and
    turn it into a rgb datastream or something this flat panel tft i have
    can use to reproduce.
    the panel has a 31 pin connector on the back of it and 16 of those pins
    are for the rgb, 4 for each ,making up the 12 bit monitor that it is, 2
    for the horizontal & vertical sync signals , 1 for the clock signal , 1
    to settle the horizontal display position and a few for power & grds.
    the others are test pins.
    so looking for a convertor or what i would need to do to accopmlish
    this project. thank you very much for your time.
  2. C. Wozniak
    C. Wozniak Guest
    Something like this board set may work for you.
    http://store.earthlcd.com/CNT-EV-gm2221-LCD-Controller
    I don't work for them but have used one of their other products in the
    past.
