LCD SOS!
Discussion in 'Electronic Basics' started by [email protected], Sep 26, 2005.
  1. Guest
    Did anyone hear about the pinout of the FSTN LCD?
    What about the software used?
    Thanks in advance,
    Steve
  2. mike
    mike Guest
    THE FSTN???
    I'd be willing to bet that there's more than one...
    mike
  3. Impmon
    Impmon Guest
    Agreed. It would help a lot if we knew the model and brand of the LCD
    in question. And that is assuming the controller board is present.
    Without the controller board, the glass board itself is basically
    useless.
  4. PeteS
    PeteS Guest
    The two major types of LCD panels are STN and TFT. They have different
    pinouts (and different numbers of pins)
    For a typical STN display, see
    http://americas.kyocera.com/kicc/pdf/c47qaa21.pdf
    For a typical TFT, see
    http://americas.kyocera.com/kicc/pdf/t57qdg00.pdf
    The number of pins and pinout of each type is pretty well standard, and
    microcontroller mfrs are putting LCD controllers onboard nowadays (see
    the Intel PXA 255/270 series for example).
    I use both (in different products).
    The biggest variation is the controller with the display (usually part
    of the unit), although the I/O (as noted) is pretty much the same. Some
    things do vary (such as frame polarity), but the basic conenctions are
    usually the same within each family. Keep in mind I am expecting the
    controller board to be attached to the LCD.
    Cheers
    PeteS
