LCD Screen for raspberry pi 3 & its Configuration
Discussion in 'Microcontrollers, Programming and IoT' started by RakeshJ, Nov 12, 2018.
  1. RakeshJ
    RakeshJ
    4
    Nov 12, 2018
    I have an old 15" LCD screen salvaged from an IBM R51 Thinkpad,which I have connected to my r
    Raspberry Pi3 unit to work as a monitor using a LVDS micocontroller board procured through eBay. Two primary issues that resulted are -
    1. Overheating of the LCD screen near the bottom of the screen where the inverter wires are seen. The screen is extremely hot to touch after 5minutes or so
    2. The display is random with mixing of colours and text not clearly displayed.
    I have followed the setup instructions to the dot. Earlier had the same connected to my laptop as an external monitor and tried various display settings with no result. Am trying to salvage this scre to use as a wall mounted display.
    Searches over the net did result in few others with the same problem no solutions were seen. Am a newbie, so would appreciate if you could offer assistance using plain language.
    THanks in Advance,,,
    _____________________________________________________________________________________________________
  2. RakeshJ
    RakeshJ
    4
    Nov 12, 2018
    Ty my issue got solved.....
    TutuApp Lucky Patcher Kodi
