LCD SAMSUNG 913N
berluscony
Apr 30, 2012
4
Apr 30, 2012
4
hello, do a good job on the forum you follow Decev time I have a Samsung 913N tesnsiune not get the output I 0V instead of 15v and 5v pote help me with some advice:mad:
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
You see that reddy-brown cylinder in the lower left corner just near the mains input? That's a fuse.
With the power disconnected, get your multimeter and measure the resistance of this.
berluscony
Apr 30, 2012
4
Apr 30, 2012
4
I checked fuzibilu is ok, bye condensatoru mention that filtering of up to 310v transformer 100/400v I, and hence do not have power
(*steve*)
25,510
25,510
Are you saying that you measure 310 volts across the 100uF capacitor?
If so, that's certainly in the range I would expect.
The next things I'd look at are the switching transistor and some of the components around it.
Please be careful as that 100uF capacitor will hold a charge for quite some time.
Do you hear any sound when you power it up (maybe a click?)
berluscony
Apr 30, 2012
4
Apr 30, 2012
4
Thanks for your advice, you can help me that would be marked on the picture to measure spostez English measurements made ​​excuses for not really get along
berluscony
Apr 30, 2012
4
Apr 30, 2012
4
Hi, Steve can help me with invertoru monitor a service manual or the components to check for
