LCD replacement
Discussion in 'Troubleshooting and Repair' started by Viju, Nov 21, 2018.
  1. Viju
    Viju
    12
    Dec 15, 2017
    Hi, I recently broke the LCD panel of my 32 inch led tv. The circuits and the other bits are working fine. Can I salvage the circuit and use it with a lcd of smaller type say laptop screen of 30 pin connector and resolution of 1366x768? The broken panel is 30 pin of the above mentioned resolution.
  2. CircuitMaster
    CircuitMaster
    48
    Dec 17, 2016
    It shouldn't be possible to use it with a smaller one. The resolution does not matter as much (if the controller is made for multiple resolutions). But a different inch display should not work. Make sure that the connectors are exactly the same, if they are and the old chip is made for multiple resolutions (including yours) its worth the risk.
  3. kellys_eye
    kellys_eye
    4,286
    1,145
    Jun 25, 2010
    Best bet would be to get one of those universal LCD driver boards for the LCD you actually have - get one with an input that your (dud) TV set can actually output i.e. composite video, HDMI-out etc.
  4. CircuitMaster
    CircuitMaster
    48
    Dec 17, 2016
  5. kellys_eye
    kellys_eye
    4,286
    1,145
    Jun 25, 2010
  6. CircuitMaster
    CircuitMaster
    48
    Dec 17, 2016
  7. davenn
    davenn Moderator
    13,145
    1,705
  8. kellys_eye
    kellys_eye
    4,286
    1,145
    Jun 25, 2010
  9. chrihern
    chrihern
    Dec 10, 2018
    You need a complete set of datasheet for that driver and LCD candidates. I trying to pair a Fluke 123 with any commercial LCD and its hard because different communication protocols and characteristics. I have some good candidates
