LCD PS transformer noise
Discussion in 'Troubleshooting and Repair' started by Tonymon1, Sep 24, 2012.
  1. Tonymon1
    Tonymon1
    Sep 24, 2012
    I have a dead Phillips LCD TV. Fuse and cord are OK. The power supply transformer makes a high pitched noise. No voltages on the output lside. Can I replace this? Is it wise to? Is it likely that something else failed? Thanks.
  2. davenn
    davenn Moderator
    13,836
    1,951
    Hi Tony
    Welcome :)
    I assume you are referring to a puwer pack thats in the middle of a cable bet6ween wall outlet and monitor ?
    Its most likely the PSU, they fail very regularly.... can you beg/borrow a loaner to confirm that ?
    they are repairable ... with a lot of effort, slicing the plastic box open etc
    much easier just to buy a replacement .... most output 12VDC at ~ 4 - 5Amps
    have a look on the label to confirm and then buy one of eBay, amazon etc
  3. Tonymon1
    Tonymon1
    Sep 24, 2012
    Thanks, but this is on the main board. The caps all look OK. None are bulging or leaking. It's just that there is no transformer output at any of the voltages and the transformer is making a high pitched noise. I am testing the voltages against the ground on the same line as the output pins.
