LCD panel problem
Discussion in 'Troubleshooting and Repair' started by canactech, Feb 4, 2013.
  1. canactech
    canactech
    38
    Jul 7, 2009
    I have a display panel that goes on a NEC 17vx monitor. Two of the flat cable that brings signals between the small bord screwed on the display and the display itself are unglued.
    I want to know if it's possible to correct the problem. I've already try to heat the cables as I read on Internet but without any result.
    The screen is a QD17EL07 from Quanta Display.
    Thank you.
    Canactech
  2. sheldonstv
    sheldonstv
    68
    Jul 17, 2007
    your lcd panel is now scrap-they can be repaired but it is a repair that can only be carried out with the correct equipment-namely a tab bonding machine,laminator removal tool etc and it would cost more than a replacement monitor would
Similar Threads
Loading...
