LCD Monitor with back light not working
Discussion in 'Electronic Repair' started by Steve, Nov 18, 2004.
  1. Steve
    Steve Guest
    I have a View Sonic VE170m with the back light flashing on for just a second
    when first turned on.
    I have the monitor apart and wondered if there is a way to manually turn the
    lamp power supply
    on or if there is a common problem with these monitors?
    Steve
  2. Jerry G.
    Jerry G. Guest
    The lamp inverter, and back lamps must be replaced to properly service this.
    ViewSonic may not sell the parts to the end user. You will have to send them
    the monitor for service. Considering the value and age of the monitor, this
    repair may be worth the cost. You will have to decide on this one.
  3. James Sweet
    James Sweet Guest
    Either the lamp or the inverter has failed. Replacing the inverter is easy,
    the lamp requires patience and steady hands but it can be done.
