LCD inverter replacement
Discussion in 'Electronic Repair' started by Tim Sampson, Dec 29, 2004.
  1. Tim Sampson
    Tim Sampson Guest
    Hi
    I think the LCD inverter in my Fujitsu-Siemens laptop is of the
    impossible to find type. It's possible that I could send it somewhere
    for repair but it's unlikely to be worth spending the money (the laptop
    has other problems).
    I see that there are plenty of inverters to be had on ebay for just a
    few pounds/dollars. Is it feasable to buy a different inverter and just
    adapt the connectors as necessary or are the voltages likely to be
    vastly different? I suppose the main problem here would be finding out
    what the output voltage is supposed to be.
    And just in case anyone has a source for the proper replacement, it's
    from a Fujitsu-Siemens C1020 notebook and it drives a Hitachi
    TX36D70VC1CAF.
    TIA for any help/clues
    Tim
  2. Art
    Art Guest
    These items are normally matched to the specific lamps they are driving.<
  3. Jerry G.
    Jerry G. Guest
    These items have to be matched to the type of lamp it is driving. Many
    times, both the lamp and module are changed together, at the factory
    service.
    I take it you called Fuji, and or Siemens directly to see if you can
    have them service the computer for you? I know that they will not sell
    the parts to any non-authorized service person, but normaly they will
    service the computer for you. At least, it will be serviced with a
    warranty of some kind if they do the service on it.
    Jerry G.
