lcd interfacing
Discussion in 'Microcontrollers, Programming and IoT' started by SNEHAL, Nov 23, 2010.
  1. SNEHAL
    SNEHAL
    14
    Nov 10, 2010
    in a lcd to 8051 interfacing diagram,what are the directions of the control lines that start from RS,R/W,E.?
  2. barathbushan
    barathbushan
    223
    Sep 26, 2009
    are you a VTU student ??
  3. SNEHAL
    SNEHAL
    14
    Nov 10, 2010
    I don't get u sir.My discipline is Electronics and telecomm.
  4. barathbushan
    barathbushan
    223
    Sep 26, 2009
  5. SNEHAL
    SNEHAL
    14
    Nov 10, 2010
    i've seen this schematic before.but the lines that emanate from RS,R/W,E .what cud be their possible directions???
  6. barathbushan
    barathbushan
    223
    Sep 26, 2009
    for an LCD module
    rs- this is used to select the command mode or data mode , the signal goes to this pin from the 8051
    RW=when set to' 0' , data is read from the lcd and when set to '1' data is sent to the lcd
    so it is a bi-directional connection to the 8051
    E=1 to operate the LCD , this pin is controlled by 8051 , so the direction is from 8051 to this pin
  7. SNEHAL
    SNEHAL
    14
    Nov 10, 2010
    thank you sir! how does a lcd function in its 4-bit mode?
  8. barathbushan
    barathbushan
    223
    Sep 26, 2009
    in 4 bit mode , both the command and data are sent in strings of 4 bits
    so Mask the lower 4-bits , then send it to the port , and when enabled by another pin , lcd accepts the 4 bits and displays it .
    next mask the upper 4 bits , send it to the port and enable it .
    Do this for both command and data modes
