LCD Image Retension
Jerry G.
LCD Monitor Retention Fix
LCD monitors do not burn in. But, they do have the possibility of
having image retention. This looks like a burnin, but it is not burned
in.
Many of dealers have been telling their customers that an LCD monitor
does not need a screen saver running, because it cannot be burned in.
They are not aware of possible retention problems with LCD monitors.
Apparently, when the LCD crystals are held in to a particular position
for a long period of time, they do not relax back to their proper
default position. There is some theory about a buildup of heavy ion
charges along the structure of the crystals that have been retained in
their active non relaxed position. It appears that on faster and
higher contrast ratio LCD monitors this effect can be more apparent.
Screens with phosphors such as a CRT or Plasma screen cannot be
reversed once they have burnin. This is because these types can be
actually burned. In these types of monitors it is the phosphors that
become burned. An LCD monitor does not use phosphors, but it can have
retention. The manufactures in both cases will not warranty the
monitor for any type of retention or burnin problems.
Running a screen saver with any type of monitor is the best solution.
How to perform the fix:
Go to My Documents, and make a folder called LCD Retention Fix, or any
name that you would like to use. What you will need are two full
screen pictures. One must be full screen white, and the other must be
full screen black.
Open the Paint program. Select Image and then Attributes. Set the
Horizontal and Vertical to be proper for the monitor resolution that
you are using.
Use the Fill With Colour option and make an all White palette for the
full screen. Save this as White to the folder that is to be used for
the LCD Retention Fix. Do the same but in Black, and call it Black.
What you want is to have an all white slide, and an all black slide.
Go to the Display Properties. Select the Screen Saver. In the Screen
Saver, select "My Picture Show", or "My Slide Show". Go to Settings
for this option. In the settings, adjust the screen slide display size
for 100%. Turn off all the special effects. Adjust the time for 10
seconds. In the Source file option, use the Brows option and set it to
the folder for the LCD Retention Fix.
Set the Screen Saver to turn on in the period of time that you feel
comfortable with. Most people use 10 to 15 minutes. Go to the Power
option, and set the system to turn the monitor off not less than 1
hour.
What will happen is that when the screen saver is used, it will be
toggling the LCD screen between black and white every 10 seconds. This
will force the LCD pixels to twist through their full range from black
to white. Eventually this is supposed to fix the problem.
For the first number of days, it may be a good idea to leave the
monitor toggling through the black to white range 24/7.
Using this option as a screen saver for any LCD monitor should be
ideal.
Some manufactures are saying that if there are retention problems with
their monitor, switching it off for a long period of time should allow
the crystals to relax back to their normal position. Some manufactures
are saying that several days should be adequate, depending on how bad
the problem is.
Comments About LCD Retention:
http://photography.consumerelectronicsnet.com/articles/viewarticle.jsp?id=25497
http://www01.keren.nl/mediafiles/247.pdf
http://www.screen-wipes.com/plasma-and-lcd-tv-screen-burn.html
Jerry G.
James Sweet
Shutting off the monitor, or enabling power management to do so when not in
use is an even better solution.
JANA
This is for getting rid of the retention. If there is no retention, shutting
the monitor off is a good idea.
We have some monitors that had retention problems. This fix really worked
well for us!
JANA
_____
James Sweet
shutting
well for us!
Yes, that's why I was only replying to the "running a screen saver" portion.
The rest is perfectly valid if it works, I've never had to use it myself.
