LCD High Contrast
Discussion in 'Electronic Design' started by [email protected], Sep 18, 2006.
  1. Guest
    Hi
    I am lookinfor LCD with the BEST contrast. I am presently testing LCD
    from various vendors.
    The LCD is used outdoor and will be viewed both in daylight and night.
    So, will require backlightor sidelight.
    Type: Monochrome
    Resolution required 128x64 dots
    Module size 93mm x 70mm
    Karuna
  2. mkaras
    mkaras Guest
    You have a challenge here as sunlight viewing is not easy. You should
    look at this site for some impressive products.
    http://www.kentdisplays.com/advantage/sunlight.htm
    - mkaras
