lcd cracked screen repair
Discussion in 'Electronic Repair' started by [email protected], Nov 10, 2006.
  1. Guest
    is it possable to replace a cracked screen
  2. On what? TV? Monitor?
    Usually not cost effective, i.e. buy a new one.
  3. JANA
    JANA Guest
    If you call the monitor manufacture, you can get the price for a replacement
    screen. They can be a bit complicated to replace. Most likely the
    manufacture will refer you to their authorized service centre. Most of
    manufactures will not sell their parts directly to the end user.
    You may find the cost of the screen replacement to approach the cost of a
    new monitor.
    JANA
    _____
  4. Not worth it, might want to check ebay for a similar unit with faulty
    electronics.
    Which is how i got my 2 eizo 18.1 TFT's
    Bart Bervoets
  5. Guest
    Guest Guest
    if u find exact internal lcd panel, then disassemble and insert new one.
    lcd panels are plummeting in price anyway. get a new one. it wil be better,
    brighter and use lesss power. probably weight a whoe lot less also.
    attempting to "fix" any hermetically sealed lcd panel is useless, nless you
    own exact manufacturing fixtures, chems, tolerance guages, etc, etc u
    know what i mean :))
  6. Possible? Yes.
    Cost effective? No, unless you can obtain an identical monitor with a
    good LCD and a different problem.
