LCd (44780 controller)
Discussion in '8bit Microcontrollers' started by Martin Mehner, Sep 9, 2003.
  1. Hi!
    help wanted! I have several (more thant 10 pieces now) of that 2x16
    char LCD here. In former times I wrote a pic assembly program that
    uses this one - worked great)
    I came up to use it again and: does not work!
    So i connected the display to an application known as working well and
    guess what: not working!
    I tried 10 different displays now all show the same behaviour.
    Anybody has a clou what went wrong?
    Mart
    ps: I take the usually precaution to ESD. And I assume not ALL of the
    displays can be defective since they withstood all my "treatings" so
    far
    -:- kill this line if u reply via email or the message will be filtered -:-
  2. Rich Webb
    Rich Webb Guest
    Not all 44780-style displays have the same characteristics for things
    like setup and hold time. If you can't get the docs for that specific
    display, try adding a couple of NOPs around the E strobe, etc. A good
    scope or logic analyzer might help show what's happening.
  3. I'll check that out thou I think it does not need a negative volage
    nor it#s a timing problem (I use a PIC clocked @4MHz so every
    instruciton is at least a 1us. But it's worth a try anyway).
    Thanks to all who answered so far.
    Mart
  4. Rein Wiehler
    Rein Wiehler Guest
    have you used this exact model of LCD before?
    Compare the diferrent model numbers you have, not every LCD follows
    the same spec.
    rw
