LCB - Linear Current Booster -- any reference designs ?
Discussion in 'Electronic Design' started by [email protected], May 23, 2013.
  1. Guest
    Could some electronics guru please clarify the difference
    between a linear current booster (LCB) and a buck converter ?
    Also is there any reference design around ? Googling the
    topic has not been too helpful.
  2. Guest
    I was curious so I googled it, it does seem that it is basically
    a buck converter, used to step down the voltage from solar cells
    so that when running a pump with solar and the sun is low it'll still
    have enough current to run the pump slow in stead of stalling
    -Lasse
