D
Don Bowey
HI Bob,
Good question:
One of the thing I am trying to do well.
I can only explain well using an analogy.
You get on a swing set, you generate enough energy so that you start swing
(oscillating) everutime you reach a peak value, you give yourself (or a
friend..) a small push to keep going the same amplitude.BUT if you keep
giving the same push everytime with the same strenght you did the first one,
you will reach a point where you will no longer get to go any higher, or
simply break and fall. In an oscillating mechanical system when you reach
that point, the machine simply over heat or break down. This is what I want
to do electrically.
K
I'm late getting into this string.... It sounds to me as though you want the
electronics to self destruct. Is that correct?
Here you are.......
1 - Amplifiers make good oscillators. No amplification, no oscillation.
2 - If you provide *enough* positive (in-phase) feedback an amplifier *will*
oscillate.
3 - At a feedback amplitude that is very near, but below, what it takes to
cause sustained oscillation, the amplifier will ring or ping with noise.
4 - Increasing the positive feedback beyond that in item 3, you can drive
the amplifier as hard as you wish, up to self destruction if you pick the
correct components.
You can make an amplifier oscillate with, or without the LC network. The
tuned circuit just lets you set the frequency at which you want (or hope
for) it to oscillate.
Don
