latching relay selector
Discussion in 'General Electronics Discussion' started by japcarmad, Sep 3, 2016.
  1. japcarmad
    japcarmad
    4
    Oct 2, 2013
    hi
    i need to build a circuit that has 4 momentary switches. each switch activates a relay that in turn will allow current to pass into a solenoid and activate it. upon the button press the relay must latch on until either one of the other switches is pressed. when sw4 is pressed it must unlatch any relays that are on and make both solenoids off.
    i have seen many solutions for this from a pure relay setup or a flip flop ic circuit designed for source/input switching. i was also contemplating an arduino.
    what advice could you give for my best way to approach this?
  2. Alec_t
    Alec_t
    2,963
    803
    Jul 7, 2015
    Please define 'best'. Cheapest, quickest, most reliable, easiest to construct, minimum components, .........?
    Personally, I would discard the relays and use logic circuits and power MOSFETs to drive the solenoids.
  3. japcarmad
    japcarmad
    4
    Oct 2, 2013
    this nor gate seems to work for two switches i just need to expand it for the other switch and power the solenoids somehow. i think this is the way i would like to go.
  4. Kiwi
    Kiwi
    363
    89
    Jan 28, 2013
    Would a 2 pole 4 position rotary switch do what you want?
    Finder 20.24 stepper relay?
  5. bob monsen
    bob monsen
    8
    Jan 18, 2010
    Software is always easier and more flexible than hardware.
