Latches, Flip flops and Timers
Discussion in 'Electronics Homework Help' started by vick5821, Apr 28, 2012.
  1. vick5821
    vick5821
    700
    Jan 22, 2012
    Hey guys, what is the difference between set up time and the propagation delay (tPLH and tPHL) from clock to output ? Anyone can help me to make me clear about it ? Thank you
  2. Harald Kapp
    11,811
    2,751
    Setup time is the time the data inputs (e.g. D, T, J, K etc.) have to be stable befor the active clock edge. If the data inpit changes in a sjorter tiem (meaning nearer to the active clock edge) there is no guarantee that the flipflop will recognize the state as intended. In the extrem case a so called "metastable" state can be reached (http://en.wikipedia.org/wiki/Metastability_in_electronics) where is can take arbitraily long for the flipflop to settle into a defined state.
    Propagation delay, as the name says, is the time it takes for the input to propagate to the output. Or expressed in a different way: the time for the output of a flipflop to react (e.g. latch data, toggle state etc.) to the active clock edge.
    Harald
