Laser Tag Gun - Short burst circuit
_Nate_
Jun 12, 2017
99
Jun 12, 2017
99
Hello! So recently I've been designing laser tag guns, but I am a little confused on the circuit. I need a simple circuit that allows one trigger pull/switch press to flash the laser diode for just a split second to prevent players from holding down the trigger. Anyone have any ideas? Thanks!
_Nate_
Jun 12, 2017
99
Jun 12, 2017
99
Edit: I'm trying to design a switch that automatically shuts off when it turns on so it's just a burst. If anyone has ideas, that would be appreciated.
davenn
14,260
14,260
Information?
you said you have "been designing" so we have to assume you have made a decent start ?
have you got a circuit ? or were you expecting some one here to do it all for you ?
_Nate_
Jun 12, 2017
99
Jun 12, 2017
99
I designed the gun models (as in 3D plastic cases) and gathered materials.
AnalogKid
Jun 10, 2015
2,893
Jun 10, 2015
2,893
Power source
Voltage
Available current
Current needed by the load
Physical size available
Quantity
A mechanical switch that makes contact for only a brief period of time when its button is pushed and held down is possible, but the E in EP stands for electronics. A circuit that takes a momentary or stationary input switch button press) and turns it into an electrical signal (pulse) of a consistent, fixed time period (pulse width) is called a monostable multivibrator, or just monostable for short.
If you are sure that the switch press *always* will be longer than the desired output pulse, the circuit gets pretty simple, a differentiator plus an output driver.
If the input might be longer or shorter than the output, then you need a true monostable, something that has feedback and control gating. Again, simple circuits, but dependent on the details.
ak
