I have a problem with a couple of honeywell MS-7120 scanners. The laser stop after a variable period but the scanner doesn't give no error. Normally these scanners emit an alarm when there's a problem. If I unplug it from the usb port and plugged it back again, the scanner is working fine for a time.
All the scanners used a usb ports and they are plugged on a Axel thin client terminal.
Thank you fot your help.
Canactech
Canactech
