I was trying to attempt to measure noise on a 6 watt laser. The main problem
is trying to focus on something without it melting or catching fire.
I was trying to look at the reflective light with a photodiode.
I guess there migh be some fancy expensive device ??
All sorts of ways of reducing the power density including lenses to spread it
(as someone else mentioned), or a simple beam sampler using a glass plate to
pick up 8 or 10 percent. A couple times and you get down to reasonable power
levels. Or get a proper beamsplitter that can be obtained to reflect
a very low percentage of the beam power. An optical filter or even a mirror
that reflects most of the beam and transmits a small percentage can also be
used, but probably only after the lens to reduce the power density so as not
to damage it.
Then any photodiode will be fine.
Those expensive devices have some means of reducing the power to acceptable
levels for their sensors.
sam | Sci.Electronics.Repair FAQ:
http://www.repairfaq.org/
Repair | Main Table of Contents:
http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ:
http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites:
http://www.repairfaq.org/REPAIR/F_mirror.html
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
