pusur44017
- Nov 16, 2015
- 32
- Joined
- Nov 16, 2015
- Messages
- 32
This might get messy, so if it does, I apologize in advance.
I am making this.
I think I have most of that setup, but unlike the person on that website, I want to add speakers to it.
The LED strips will use this.
I will use these speaker elements.
I understand I will need som kind of amplifier, but since I plan to send music to it using a chromecast audio,
I won't want individual audio control. The chromecast runs on 5v/2a.
Continuing from the circuit on the website is it possible to power the chromecast and the audio amplifier from this one PSU?
I need help finding an amplifier/IC to use (4 speaker elements @ 4 ohms 3A) when finding one please use this site as the cost is an issue.
I might wish to have some kind of switch (relay) between the lights part of the project, and the speaker part. I don't mind much how this is controlled as long as I can do it without too much fuss and it's wireless. (Seeing as the project already uses IR, you might want to use that, but if you propose a solution using this, bear in mind that I won't know how to code that in the Arduino, and therefore help in that department is much appriciated)
Feel free to ask if you need more information on the components I plan to use or other.
I think I'm using the same parts as described on the website. I also need help on some Arduino coding and made a separate post here. Please feel free to pitch in if you can!
Thank you in advance,
-pusur
I am making this.
-pusur
