M
miso
miso said:miso wrote:
On 10/22/2012 2:22 PM, Joerg wrote:
Folks,
Looked at Digikey and some others. Where are those huge capacitance
varicaps? The ones with several hundred pF of range for AM radios. All
gone lalaland by now?
Even the ones I found in the 100pF range are either obsolete or not
recommended for new designs.
What I am trying to do: I need to control a switcher chip in frequency
because I've got a very resonant load to deal with. Unfortunately it
sets the frequency with a timing cap. I'll have to somehow vary that
between 750pF and 2000pF. Can also be digital but then with a
granularity of 5pF. The sawtooth voltage across it is 2.5Vpp.
Doing it with caps and a mux chip or two has its own challenges. The
ADG-series from AD is around 11pF per pin, otherwise their Rdson is too
high. Talking about the a rock and a hard spot here.
Oh, and cost is not very important. If a diode or two or three are
needed that cost $5 a pop that's ok.
There are plenty of hoarders that have those caps. I picked them up
years ago when I figured they would go extinct. They same goes for 10
turn pots of the panel variety with the dials on them. (Good old Mike
Quinn in San Leadro by the Oakland airport would save panels with those
pots and junk the rest of the product.] Most radios are synthesized
these days, so there is no market for those caps.
Yeah, I know but I was hoping there'd be at least one other market.
Seems like there ain't.
If you are not conflating sawtooth with triangle wave, then maybe you
could shunt some current from the osc pin, which would slow down the
frequency. Pick your external cap for the highest frequency needed, then
bleed with some DAC based circuit or even a resistive trimpot. The
10-turn PCB mounted resistors still exist.
The difficulty will be in the compliance of the current source used for
bleeding.
That won't be a problem but the chip immediately gets sea-sick when you
do anything DC to that pin.
Is this pin where you see the sawtooth? Seems to me with a high
impedance current source, you can steal the current. Now a triangle
waveform is a different case.
So you have tried a high impedance current source?
Yup. The chip then starts to misfire, big time, at least on the simulator.
None I ever designed would care.
BTW, you can always make a sawtooth generator go faster by inserting a
resistor in series with the cap. Basically it adds a step to the saw
tooth, getting you to the limit faster.
