K
Koen Vermeer
I have some basic knowledge of electronics, but I'm having trouble trying
to get some real design to work. One of the things that do not work as
expected is the BS170 MOSFET I'm trying to use. I know, it's not a very
sophisticated part, but I have a few of them lying around and I thought
they would be able to assist my learning.
Anyway, I connect the gate and source of the BS170 both to the ground,
and the drain to a 330 ohm resistor, connected to 3.6 V. When I then
measure the potential of the drain, it's at 2.85 V, which means it draws
a current of (3.6-2.85)/330 = 2.3 mA. Thus, the drain-source resistance
is about 1.2 kohm. My expectation was a much larger 'off' resistance (say
100 kohm or more).
I cannot relate anything on the data sheet (http://www.fairchildsemi.com/
ds/BS%2FBS170.pdf) to my observation. I tried with another BS170, which
gave about the same results. Is my expectation wrong? Apparently, it is,
but what is the right explanation? And, how can I deduce this from the
data sheet? Then, how to solve this? Should I just use another
transistor, or is there some common way to handle this?
In my case, I connected a LED to the drain and it didn't shut off. I can,
of course, put a resistor in parallel, but that would increase power
dissipation and would reduce the LEDs brightness when turned on.
Thanks for any insight!
Koen
100 kohm or more).
Koen
