Got my new battery today, and it's still the same, £30 gone.
So with my limited knowledge, either something should discharge the capacitors(if it is them that hold the power) when the laptop is turned off, and it's not doing it, or,
the laptop should still start with the charge still in the capacitors, but something is stopping it.
The laptop is working perfect, the new battery charged up fine and it's now running on the new battery with no problems, but when I turn it off it wont start unless I remove the battery and hold the power button for several seconds.
Any one any ideas?
pete.
Just to add: searching the net I've seen several threads that tell you to remove the battery and hold the power button for 30 seconds if you have a start-up problem, so it is a known problem only it seems to only happen occasionally with other people, with me it's every time.
